gs to a gsx??
Status
Not open for further replies.
93gskid
Dec 22, 2004
Waukegan, Illinois
I am trying to figure out how to convert my brothers 93gs to a gsx. I have measured his against a friends gsx and they are almost the same in every angle. Is there anything I am missing? Will it bolt up or is there some serious modifying I will have to do? I have done a gs to a gst converting the motor and trans. Just woundering if this is possible. If it is has any one none it and how did it turn out? Any help would be awesome.
Thanks for the help. And keep up the great work on the rides seensome pixs in profiles bad rides. Peace to all dsmers! :thumb:
yes.
it's not a bolt-on affair and not worth the time or $$$
RamenPride said:
yes.
What he said. With the time and money you would need to invest you would be better off to sell the car and buy a GSX.
Among other things the sheet metal that makes up the rear suspension mounts are different between the two cars. So, not only will you be replacing the hatch floor but you'll be replacing the rear strut towers before you even begin to swap suspension parts.
Steve
It's realy not worth it there are a ton of different parts in the rear of the car besides suspension, brakes , diff you also have a different fuel tank. If you want an awd buy one its much easier.
Status
