groove inside of oil pan and load knocking
russell3123
187
May 6, 2006
peabody, Massachusetts
I just finished a 6 bolt rebuild and its rapping pretty bad. THere is a groove on the inside of my oil pan that was there before the rebuild but it was rusty and now the rust is gone and looks fresh. I didnt see any marks on my rod caps or crank. MY oil pan also looks like a 7bolt pan but all holes lined up with the block. I checked all bearings and the only thing i could see was small scuff mark on some of the main bearings. All specs where checked and were in spec.Any one have any idea of what the problem is?I also tried installing .25mm bearings on the crank and it wouldnt turn at all by hand.
Put some blue silicone or something that is colored on the rod cap, then put the pan on and turn the engine over by hand. Then take off the the pan and see if their is blue on the pan. Then you will know if that is it or not. If it is, try a different pan. Or check if yours is dented for some reason.
It could if it keeps hitting the pan.
And if your bearings aren't bad, then I would doubt it's really a rod knock. I would keep the bearings in it that spec'd out ok, rather than putting larger bearings in for no reason.
  • For sale 2g 2GB Eclipse Reverse Lights ( with bulb sockets )
    2GB Eclipse Reverse Lights ( with bulb sockets ) $35 + shipping & paypal feesYou must be...
  • For sale 2g Tan Sun Visor Set ( with home button & hardware )
    2G Tan Sun Visor Set $50 + shipping & paypal fees* home button * hardware includedYou must...
  • For sale 2g 2G Black Ashtray/Cup Holder
    2G Black Ashtray/Cup Holder $35 + shipping & paypal fees* both sides open and close as they...
  • For sale 2g 2G OEM Radio Brackets
    2G OEM Radio Brackets $35 + shipping & paypal feesYou must be registered to see element.
  • For sale 420A 420a Miscellaneous Parts
    Hey Guys I have a 420a car that just came in, if you’re looking for any miscellaneous engine bay...
