Grinding gears with new clutch
mjdude03
Feb 19, 2010
Cheshire, Connecticut
I just put in a new ACT Clutch and transfer case and I was driving yesterday and it grinds on random shifts to random gears. How do I fix this? I have heard bearings need to be replaced, cables stretched, what should I do and how do I do it? Please help.
Also you should check your clutch slave cylinder and the master cylinder, I put an OEM clutch in my car recently and the original slave cylinder crapped out shortly after. Check to see if its leaking fluid inside the boot of the slave cylinder.
Jacks's transiossions has a very good HOW TO adjust a master cylinder video. Watch it and you will have a very good grasp of what is going on.
Chris
