DSM IN MN
Supporting VIP
- 705
- 23
- May 17, 2009
Wadena,
Minnesota
Here is a problem my friend has/had in his '95 GSX he picked up. If the car was idling and you pushed the clutch in and went to put it into gear, it was almost as if you hadn't pushed the clutch in. The transmission would grind and if I remember correctly, rarely would go into gear like this. It would happen in every gear. So to get it to go into gear, you would have to slam it into whatever gear you wanted as quick as possible. This worked 98% of the time.
Here are the modifications according to the previous owner:
6 bolt swap, ACT 2900 pressure plate and street disc. Fidanza aluminum flywheel. Welded differential.
On top of this is has solid under hood shifter bushings. I do not think this would make too much of a difference; especially with the grinding.
My theory is that possibly the clutch is dragging a little causing what you would expect to happen if you tried lightly putting the car into gear without the clutch peddle pushed down.
What are some of your guys' suggestions on what to look for or possibly adjust to decipher if this is a clutch problem or a trans. problem? The car is not currently running (isn't that a surprise), so I would like to set up a plan of attack before the car comes off of it's jack stands.
Thanks in advance.
Thanks in advance.
