Green Injector Size
SFRacingGST
235
May 4, 2004
Warren, Rhode Island
Just bought a FP Green Turbo, I was wondering what injectors sizes would do? I have DS link so i can handle big ones, however i want to choose the best fit size. Please let me know what you guys think.
There is no "best size" injectors. You have a min. requirement which I would say is 660cc injectors. If it were my car I would go with injectors in the 880-950cc ranges for various different reasons. Most of which are lower DC and less heat.
Since you have DSMLink, I would recommend around 950cc or larger as a minimum - with DSMLink you will be able to tune these to operate as smoothly as the factory injectors. There is no reason/benefit to choosing a smaller size injector. Also, by installing these larger injectors from the start, you will avoid having to upgrade them again in the future should you decide to upgrade your turbo again. Good luck with your decision.:thumb:
These guys are right. I was already hitting 103% IDC with my 650s on a 50 trim at 22psi. I swapped in FIC 950s and am good to go!
