greddy type s install Q
avaien
242
24
Nov 30, 2003
Cincinnati, Ohio
When hooking up the greddy type s do I put the T fitting, im guessing for the boost reading, in the fuel pump preasure or do I put it inbetween the bov and intake manifold? or somwhere else?
Are you asking were to get your boost source from for the boost gauge or the boost controller?
A Greddy Type S is a blow off valve. There should be no t-fitting. Use the stock blow off valve nipple to the very top nipple. This tells the BOV to Blow off.
You don't need any of that. All you need to do is remove the stock BOV and drop in the Type-S. Use the same line that was connected to the stock BOV (coming from the intake mani). That's all there is to it.
I assume you're referring to some of the parts that came with it?
the t fitting that comes with the blow off valve is for the bottom (smaller) nipple. it's optional to hook it up it spilts the vacuume line from the lower intercooler pipe that's what i read when i installed mine it's suppose to apply pressure the the valve in th bov but when i did it i boosted to 25 pounds. but that might not be the same for you any way good luck
  • For sale 2g 2G Clear Tail Light Set
    2G Clear Tail Light Set $550 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
