Greddy Turbo Timer Problem
groovedmb
Sep 9, 2004
seattle, Washington
Ok, I did my search, and couldn't find the answer.
I've installed my Greddy TT with a greddy harness. I've hooked up the ebrake and speed sensor correctly (or to my knowledge anyways)
It works correctly, all functions work. But here's the problem:
Quite randomly, when I use the turn signal, the TT will turnoff then immediately turn on, but it'll loose it's count.
I have it mounted on the steering column, so at first I thought it was vibration. But I recently discovered it has nothing to do with movement, as it restarts when you just barely click the signal. It recently started doing it when putting it into reverse. So I think it's electrical.
Anyone have any experience with this?
which wire did you hook up the speed wire too i need to know which one it is on the ecu???
sorry to bring up a very old topic, but did anyone ever figure out the cause of this? I have been trying for years to crack this problem.
  • Wanted 6 bolt NT water pipe
    • chrisman287
