GReddy Turbo Timer HELP!!!
TurboDreamzGST
240
Dec 22, 2005
Howell, New Jersey
i have a 97 GS-T with a GReddy Turbo Timer installed....now the car came with the turbo timer and i don't have the owner's manual...i need help setting the amount of time that the car stays running for...right now the turbo timer is set at 2 minutes but i want to change it to 1 minute.....i dont know what model the turbo timer is but its a GReddy Full Turbo Timer with a blue display screen.....it has 3 buttons on it for the power, the time, and select....can anyone help me and tell me how to set the amount of time the car stays running for please??
Thank you,
Mark
i have the same one, press the select button on the right until the desired time comes up.
when you get it to were you want it, it should go blank for a sec and show a letter weather it be L , H , or P1 or P2 and then it will show the time again.
to choose weather you want L , H, P1, or P2, hold down the power button and at the same time press the select button until you get the one you want.
hope that helps, and someone correct me if i'm wrong, im just trying to visualize how i've done it in the past.
    • dsmmario
    • Detail
    • dsmmario
