kicknurass4fun
- 141
- 5
- Sep 5, 2005
Fox Lake,
Illinois
Ok so I have a greddy RS bov and I have been trying to get the thing set up properly and im having some problems that I am curious as to if any one else has had? When boost testing my car the bov will leak if I dont have the spring tension set pretty high. The problem with this amount of spring tension is I get compressor surge when ever I shift with less then 5psi of boost. Now I know the Greddy type S bov had a lower nipple that you could hook up a second boost/vacume source from inbetween the the turbo and the bov. This made the bov react faster to help at low boost levels with high spring tension. The RS doesnt have this. It just has a hole for the air to vent through. My first question is has any body else had this problem with the RS? Second has anyone drilled and tapped that hole to put a fitting in so that it can be made to have a boost/vacume line attached to make the bov quick release? Thanks
