Got my Tsi 4 weeks ago
From what I can see, it looks like a nice car man. Congrats.
All maintenance that hasn't been done yet.
+1. Maintenance, alignment (if needed), oil change, you know the drill.
Get the car in good healthy shape first.
Then move along to the stage 1 path, i.e. boost and oil pressure gauges, wideband, mbc, intake, exh. just to name a few to help liven the car up a bit.
Did all of that, so stage one is done. change plugs to iridum ngks, oil change/ ngk R wires 3 in down pipe to straight pipe apex i N1. all guages cobalt air /fuel etg and boost. but what else.. de jon intale with aem dry filter too.
Good job, now that you have all that out of the way, for intake don't get dejon or injen, it's a bit overpriced.
I wouldn't go ebay either, why you ask ? Their couplers and hoses are crap. I'm anal about stuff like that, that's just me. I would go middleman on this one, extremepsi sells an intake for a reltively good price and comes with a filter and real good 4 ply silicone couplers.
I bought my intake from them a year ago and it's working just fine. Only thing i changed is the filter to k&n.
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Extreme PSI Intake Kit : Mitsubishi Eclipse Turbo 95-99
Already bought and on, also put the slow boy full intercooler system along with the greddy RS blow off valve.. :ohdamn:
I would go with some NGK BPR7ES plugs. iridum plugs are nice but I've found that the BPR7ES plugs work the best plus there only like 2.50 a plug instead of 10- 12 bucks. You have done a good job with your list of starting mods. And every one has listed almost everything else. So I guess you could do a 1g Throttle body or ported o2 housing. New Break pads and rotors wouldn't be too bad.
I tried to list things that I don't think anyone else did but if so my bad
I'm trying to get my car fast and make it fast quick there is alot of evo's out here and srt-4s that are running open down pipe sounding mean.. I have everything I got listed in my profile I have a 60mm throtle and pur drilled and slashed rotors with new break pads.. Just trying to see if i can hang with the big boys.. :sneaky: I'll put my big turbo soon..
By did all of that, do you mean, all of the maintenance or the stage 1 mods? By maintenance i mean timing belt, tranny fluids, transfer case fluids, assessory belts if they need to be done etc etc.
damn i see that you dont play when it comes to modding your talon keep up the good work all i can say is buy a spare motor and start building
