Got my 91' eclipse. Need help.
TRMotorsports
58
Oct 13, 2002
I seen somewhere on the fourm that you can turn the stock boost up a few pounds. Is this true and if so what supporting mods would i need to keep the air/ fuel in check? Thanks for the help guys.
my friend turned his stock up to 17 lb. thats about the limit before fuel cut but youl need to upgrade your fuel system (injectors, fuel pump, etc.) if your turbo has high miles i wouldnt turn it up to high or youll be running no turbo pretty quick:dsm:
Thanks for the info i will look into the free mods. Yeah sorry about the search thing. The guy said it has the wrong injectors in it so i have to get new ones. Should i get stock or go ahead and upgrage? There is another problem i gotta fix to. Thanks for the help guys.
