Good way to start out 2013 - 9.68@138
Congrats on the times! That converter sounds like a no go imo. If its slipping that much you should atleast be able to footbrake up to 3k or more without nitrous. Sounds like its tight down low and loose up top. Complete opposite of what you want. I can footbrake my ipt 9" to 3500 with no nitrous. I'm on a 2.0 with a divided t4 1.00 a/r 6766. With a 26" tire mine goes through the traps around 145mph at 9k and I think that's still pretty loose up top. Also does the car hold on the brakes fine at 4500rpm? The reason I ask is because that seems a bit high and if your holding back to much torque on the line it will cause transfer gear failures. I would lower the 2-step a bit and see what happens to the 60'.
It only holds because I retard the timing so much when i'm at the 2step RPM. When I had it at normal timing, it blew through the brakes. When I let off the brakes, timing ramps back in quick. I'm giving Mike a chance with this thing but if something doesn't happen soon, i'll have to look elsewhere I guess.
Great way to start off the new year !! I hope mike can tighten up the converter....
That it was, Steve! We'll have to do it again soon! I'm getting my physical for the 9sec license this week so i'm game after that!!
Awesome! Let me know Ill go again.
Let me know too when you guys go! Hopefully Ill have a little more time this time to get my car back to 35-37psi and try to knock off a 10sec pass on this stock 6Bolt 5speed turd with a 56mm turbo.
You had the black 1g? Will definitely let you know. Its nice having a bunch of DSMs together. What turbo do you have on there?
Argh I hate that my talon isn't running so I can head to Atco with you guys!
Great times Chris!
How much more do you have Tom? Let me know if you need help with it.
AEM should arrive today, made a deal with the Sandbox for his 1650's, picked up a T4 manifold but I still need to do a lot like Swap trans & T-case but I need to pick up a new clutch and flywheel first, need an AFPR and fuel filter for my massive -10 feed lines, turbo & lines, and then just some small things.
It's not a lot of stuff but it requires cash and time. Hoping to finish the fuel setup this week with a trip to extreme soon then setting my sights on the cluth & FW. Damn car...
I have a new converter showing up in about two weeks from Sinister that should couple a lot tighter up top. Can't wait to try this thing out and see what we see at track!
Which converter did you do this on
I was a beta tester for the 8 inch converter selection both core 1 and core 2
I am currently running the core 2 but havnt been able to get back to the track.
