Good Match? (audio stuff)
In-Serenity
Jan 17, 2004
Hazlet, New Jersey
Hey,
I'm not really experienced much with car audio so I thought I would ask my questions here. I'm looking for a Mono Amp that will provide slightly more power to the Alpine Type-X subwoofer running at 2 ohms. The one amp that I have in mind, HIFONICS BRUTUS BX2200, is advertised as a Mono Amp. That is where my first question comes in: when I look at the pictures, it shows 2 speaker outputs. I thought a Mono Amp should only have one. Here is a link to a picture of what I mean: http://imagehost.vendio.com/bin/ima...tz/bx2200ee.jpg.
If anyone could explain this to me, I would appreciate it.
Second question: are the two products compatible? Here is the specs on both.
BX2200:
# 1 x 550 Watts @ 4 Ohms
# 1 x 1100 Watts @ 2 Ohms
# 1 x 2200 Watts @ 1 Ohms
# 1 ohm stable
# D-Class Design
# Variable Bass Boost
# Ultra-Fi MOSFETS
# Zeus EVXP (Exponential Vari-Power Supply)
# Simpatico Coiled Design
# HSMD - Hifonics Surface Mount Design
# Fully Adjustable Accu-Cross Crossovers
# Regulated Power Supply
# 0.08% THD
# New ultra efficient design
# Line Output for Amplifier Daisy Chaining
# Variable Bass Equalization
# Variable Sub-Sonic Filter
# 2 Gauge Power Connectors
# Additional High Speed MOSFET Output Devices
# Maxi-Fuse
# Subsonic Filter
and here is the info on the
Alpine Type-X Subwoofer:
# dual 4-ohm voice coils
# frequency response 23-200 Hz
# power range 500-1,000 watts RMS (500 watts per coil)
# peak power handling 3,000 watts
# sensitivity 83 dB
Thanks,
Samir
yeah butI'd go with something a little different in terms of amp
maybe a jbl gto 1200.1 ($550 MSRP)
a mono amp is more efficient with a dual voice coil woofer if you run each coil to each set of outputs versus wiring in parallel or series. usually only "better top of the line mono amps" have the dual outputs. Just look at the rms on the amps and match it to the rms on the woofers and you should be fine. just don't get an amp that is under powered it will not only sound like ass but will ruin your woofers.
why run twice the wire? :confused:
using both outputs is parallel. wiring the V/c in parallel saves time and wiring.
Hey,
that sub is rated for 1000w RMS. Wouldn't 1000w per coil be a bit too much?
And also, what would be the better way to wire that DVC sub to the amp Attack_Eagle suggested? I want to have the least resistance and most power to the sub that the amp can provide.
Thanks
wire both positives and both negatives together, then 1 wire from each to one set of the amps outputs.
500 per coil = 1000 rms per sub... not 2000 watts
1000-1200 w rms amp will be excellent
