good fuel pressure tester?
1Gina2G
810
May 6, 2011
Beaufort, South Carolina
Was wondering if anyone knew what to look for when buying a fuel pressure tester for a 2g fuel rail? What kind of fitting fits the fuel rail? Will the actron tester at advanced auto / autozone work?
Ive researched and it's been asked but the links in the older threads are expired and all I've found is that stock fuel pressure should be 43.5 and that you should add in your expected boost pressure (15-30 psi)
Does anybody know of what fitting to look for? Where would you hook up the tester?
