glo gauges no work wtf
ericismyname
682
Oct 14, 2002
West Des Moines, Iowa
aight so i got some glo gauges right, got em all done nice n fancy n what not. I finally go to get a power supply. so the positive supply fromt he dimmer doesnt work. and the red power suipply wire from the fog lights dont work (probaly becuase i dont have fog lights) and then i tried the cigertette lighter and it still didnt work. But does the ciegerrete lighter only work when the ignition is turned? or does it work no matter when u use it? i dont smoke so ive never used it in any of my cars. :thumbdown
Just get a jumper lead and attach it to the positive terminal on your battery. Make sure you have a good ground also (it helps to have a test light - they're pretty cheap at your local parts store).
The gauges would always be on if you attached it to the postive terminal of the battery.
I suppose you could use a switch...
Yeah, I know. I was basically just making sure they're working correctly, I wasn't meaning for it to be permanent.
just hook them up to your rear defogger or something. I hooked mine up to my Evac button so that they turn on with my headlights.
