Prodigyman
- 215
- 0
- Jun 22, 2004
Toronto,
Just got my 97 GSX and buying new upper and lower intercooler piping and FMIC. I have a stock turbo with stock parts like injectors and such I presume.
I have aftermarket intake and 3 custom made exhaust (from the turbo back) with Magma Flow High flow cat and muffler with Greedy Type S BOV venting back to intake. I am wondering what is the safe boost I can pull with this setup and stock T25? Is it even worth installing all that? @ Stock boost ~8 PSI I believe would it make a difference with the piping and FMIC or would it create more backpressure for the small turbo to pull? Would ~ 10-14 PSI be okay with this setup?
Any suggestions and your answers are appreciated.
. that is, if you go above 16 constantly. i suppose if you bump it up to say 19 every one in a great while, it wouldnt hurt it too much, but you will still be pushing the reliability issues here.
Turning up the T25 will get you more power but it will mostly make hot air because it will be operating well above where it is most effiencient. If you can get a good deal right now on the FMIC now go for it and install it now. I ran a front mount with my T25 for a while with no ill effects. You will really start to have fun when you get a bigger turbo.
Same goes for GReddy Profec B-Spec I just got. Also I would not be putting anything remotely close to 16+ PSI nor plan on doing so, not sure were you got that idea. If stock is ~9 PSI I be pushing it around 12 and when I want power then ~14 PSI.
i know what u mean! I feel that way already
