2G Getting ECMLink V3 Used Need Help
Rekadae
54
10
Jul 14, 2017
Lapeer, Michigan
Alright guys coming at you with another request for some advice, I've looked around but it seems like there's very vague information on this.
I'm buying ECMLink v3 for $300 that came out of a 800whp car.
So I currently have a no start issue that I'm addressing atm which is completely separate. Although obviously the settings on the ECMLink are going to be wrong for my setup.
Will I be able to adjust the settings with the car off safely?
What can I adjust with the car off?
What are considered some pretty baseline settings to start the tuning process?
Thanks ahead of time guys.
1.) Yes you will be able to adjust the car safely in off mode
2.) Yes You can adjust the fuel setting like injectors etc
Welp that’s my expertice LOL. Well hopefully somebody else can charm with alittle more experience
Well that's pretty cheap for ecmlink.. anddd yes. you can make all changes with the car off. have you watched the intro videos yet on how to use ECMlink?you should watch them. and then watch them again. probably 3 or 4 times before you even go out to the car. Or better yet, have the videos loaded on your laptop and take it out to the car and watch the videos as you make changes.
http://www.ecmtuning.com/demos.php
