Gauges!!! ahhh
kmartsTsi
Dec 24, 2005
Hubertus, Wisconsin
Hey, new to the site and i got a question. My 1991 Eagle Talon Ts i's Engine Computer (ECU) stopped working about a month ago. I got it rebuilt, and now the car works fine. My problem is that now my speedometer is the only gauge that works!! Before, all the gauges worked fine. I've checked the fuses and they all are fine. I was wondering if you could help me out. Please email me at [email protected], or call me at 414-416-9171. Thanks.
Kyle
I called the place who did the rebuild, and they told me that the ecm does not influence the gauges. ???
Hi. That is absolutely not true. The sensors for your gauges send a signal directly through your car's ecu. That statement alone makes me think that they werent competent to touch your car's ecu in the first place. GOOD LUCK and I hope everything works out.
Ok, heres the deal. I sent the ECM back to the company that rebuilt it. He tried it in their test vehicle, and all his gauges worked. As said before, all my fuses are good, and the wire is hot from the ignition. He said i should look for a switch that comes from the fuses. I was wondering if anyone knows what this swith looks like, or a part #, or any info that will help. Thanks.
