Gauge Pod + Boost gauge install question
Phippsp
81
Sep 28, 2005
Port Royal, Pennsylvania
Ok I have done alot of searching but I need some specific information answered that I could not find on here or vfaq.com
On this link from vfaq : http://www.vfaq.com/index-main.html
It says trace the fule pressure line with blue strip on it. I have done this it says you will want to tap into the line right below it that leads to the center of the manifold im dumb founded here I can't find anything related to this going to the manifold or even a tapable line below the fuel line with the blue strip on it.
Next question I have Autometer C2 boost gauge and it has 2 wire hook ups on the back the 12v and the Ground wire. Most places that I have read about hooking up the 12v to the dimmer switch it says you need to splice two wires from the wire harness to make it work. Well the way the gauge looks I will only need to run 1 12v power wire somewhere.
Thanks!
What gauge wire would you guys recommend to use to connect to a 12v power source ? Sorry for digging up an old thread, just want to confirm.
