Gas tank problem
goldeninja20
589
3
Dec 5, 2010
Norton, Massachusetts
I went to the gas station, had 3/4 tank of gas. I put over 25 in until i realized it was leaking bad. I just replaced the filler neck and vent. I only plugged these 2 nipples on the tank, i cannot figure out if there are more than 2 nipples. I am thinking i left a nipple unplugged and it is just leaking out, I have no evap too. If someone could let me know how many lines come off the tank it would be great to know, or if you have any input.
Maybe checking the line that goes to the engine, and you can also check the gas tank gasket, you'll have to pull the back seat out, and open it like if you were going to change the fuel pump, this happened to me once that it was leaking from there.
Good luck
