Garrett t04 onto 95 gst
sweetjumper32
53
Feb 28, 2004
Florence, Oregon
Hope this is the right forum for this question. I have a 95 Eclipse GST, and got ahold of this turbo for cheap (Garrett t04). My question is, what is seen in the picture is exactly what I have. What parts will I need to put this on my Eclipse? The engine and turbo are still stock. Thank You.
You're going to at least need a T4 manifold (which I happen to have an extra of if you want it for cheap ;) ), an external wastegate, and new plumbing (you'll need to feed it oil, return that oil to your oil pan, and possibly feed it collant).
That's at a min. You're also (obviously) going to need supporting mods, some sort of piping solution (as it will exit at a diffrent angle then your T-25, T28, 16G etc....), and most likely slim fans to make sure there is suffecient clearence. I just installed a T4 on my car, so if you need a parts list, etc...I can help you out.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
