95 gst will not start!!!
boosted99_420
307
Apr 26, 2010
Fort Carson, Colorado
Hey, ok now im haveing major trouble with my 95 gst. Its stock except for greddy upper hard pipes, bov, and exhaust. Its a new starter, alternator, and battery. When i turn it on and turn key to start it clicks one time and nothin else. It started out driving ok, the after class i started it and it cranked but died like 4 times. then on the way home started losing power in all gears. I some how got home and parked it then cut it off, cranked it again and it started right up then i killed it and tried to start again and click nothin. So i changed starter and alternator and nothin. I tried another gsts ecu and same story.
:banghead: So if anyone can help let me know.
:banghead:
Ok was working on it some more today (checking ECU etc.) and still doing the same but i realized its not getting enough power to the starter to turn the engine over. I turned on the headlights to see and i tried starting and they didnt dim very much at all so virtually no power is going to the starter if i understand it right. So is there any thing that would cause not enough power going to starter besides battery or possitive and negative cables?
Have it towed to AutoZone or something like that. They'll check the battery, alternator, and pull any check engine error codes you have for free. If nothing else, you'll at least know that it's not the battery or the alternator!
i have a friend thats commin over this weekend thats a DSM expert. But i did remember i let the battery drain by accident when i was so tired i passed out in the car with ignition on after i turned engine off. So maybe the battery is toast, but the stick on it says 10/10 so idk if thats when they bought it or when it was suposed to be sold or discarded.
