GVR-4 galant vr4 ecu same as 1g eclipse?
Correct me if I'm wrong, and I probably am, but aren't the pins for the MAS different?
The ecu's are the same as 91-94 1g ecu's. Also all GVR4 ecu's came eprom.
If your friend has a 90 then, he will need to change 2 wires on the ecu, you can find them on here or vfaq also. I believe it's pin 14 and 6 but I could be wrong on that, I'd look it up. :thumb:
