FWD parts into AWD car
guamboyeli
125
May 24, 2012
North las vegas, Nevada
I have a 91 FWD eagle talon.... and i have 92 awd talon project... my awd is in pieces and needs a rebuild... my FWD is my daily but when i did my new set up, i burnt the harness and ecu... so I want to use my fwd as a donor car and put everything in my awd.... So my Question is what can i transfer from my FWD to my AWD???
Everything will swap over, just remove the driveshaft/t-case and drop in the FWD trans. You can also remove the rear diff/axles and find a junk 3 bolt, gut it, and bolt it in to hold the subframe together to save some weight.
  • Wanted 6 bolt NT water pipe
    • chrisman287
