fuse for doors and windows
dsm96rs
269
Oct 11, 2010
Glendale, Arizona
i have looked through the tech forums and i have found that in order to just buy a power door and window assembly i will also need to make sure i have the fuses in already for those. however....i see that there is a specific fuse spot for door locks but is there one needed for windows to work?
and please send me diagram if so.
thanks
Power windows have a 30A fuse in engine fusebox (one on right in row of 5 for NT). But it also has a relay under the dash and uses part of the etacs-ecu. If you did not have power windows you might be missing a lot of the necessary wiring. Send me a pm with email address that accepts attachments and I'll send you the factory diagrams.
