Fuse box relocation on 1g?
Cynxe
263
6
Feb 19, 2015
Ottumwa, Iowa
Can anyone explain how I can relocate my fusebox in my 1g? anywhere thatll make the bay look cleaner?
you want the bay cleaned up then relocate the battery to the hatch, romove cruise control and use parts from the cruise setup to make it so its only about 1 foot long, get short route fmic such as the vrsf kit, take and lower all the stuff on the firewall, remove the loom from the wiring on the harness near the intake manifold then take and run the wires all under the fuel rail so you cant see it everything will reach as is no cutting nothing like that, remove all emissions if you can do that in your state with all that done you can get to everything under the hood pretty much without removing anything will make that bay look great without doing a major wire tuck
i have a pic from my 2g with the wiring thing that i mentioned done before and after if you would like to see how much it helps i can post them pics to show you it makes a huge difference
Post them! I'd like to see the difference
