Fuse box Relocation Confusion
Biscuit33
31
Jun 17, 2013
Port Neches, Texas
I've come to the last couple of wires and it seems I've done something wrong.. These wires connect to the taillight relay fuses the only ones that aren't connect to anything else is the red and whites, in the first picture when I'm pointing at two wires, my middle finger is pointing to the wire connected to the relay (right side of the relay) itself and my index finger is pointed to the one that connects to the 10a fuse (these two wires merge into one.)..........in the second picture my index finger is pointing to the red and white wire that is located on the left side of the tail light relay... I've traced the two wires (green and white [left side] and blue and white [right side])above the red and white wires connected to the relay back to these connectors.... GREEN AND WHITE (C68) which is the "instrument panel wiring harness and engine compartment wiring harness combination" and BLUE AND WHITE (C48) which is "Engine compartment wiring harness and junction block combination [large 8 pin]." Neither connector has a red and white pin slot and I'm sure I didn't take one out, if anyone can help please do so as soon as possible.
I have a gut feeling that these two wires connect to each other but I would like some assurance before doing it.
