Fule pump Problems
2tsi_auto
Jan 27, 2006
Fargo, North Dakota
I just put a 255 fule pump in and know my car does not want to start. It does not get fuel. If i pump it, it will finly start, but it will not stay running anless i keep it around 3000 rpms. Ater about 2 minits the pump starts i wine like thay do and the car stays running what do i do to fix this.
I don't understand.
you say it gets no fuel but if you pump it (pump what?) it will start but won't stay running unless you keep it about 3000 and after 2 minutes it is fine?
DId you install it correctly (hint o ring?)
Do you have an AFPR? what is your fuel pressure at idle?
The car wont start if I do not pump the gas, and it wont stay running unless i hold the gas for a couple of minits. then the fuel pump will start to whine and then it will run.
Your symptom are strange. I also had no fuel after the install of my 255, it ended up being the harness. I guess my removing the connection and then pluging it back again was not good enough. after spraying it with contact cleaner and cleaning both contacts (clean them well). I have not had any problems. Its been 1 year now knock on wood.
most likely it is your connector.
But attack eagle could also be right. When you installed the 255 did you lube the O ring? Are you sure it seated properly. If it didnt you wont get any fuel pressure and your car wont run.
I just put a 255 in my Evo and the damn thing is quiet as hell. You shouldnt be able to hear it very easily.
Pull it, and reinstall would be my suggestion
i have a friend with a 190 walbro fule pump and u can hear his fule pump in a 2g eclipse. hell i can hear my stock one when i have my back seat out LOL. your evo one must be farther away from u or no were near u in the car. i wouldent really compare a fule pump in an evo to a 1g or 2g dsms. they are a whole diffrent kinda platform:notgood:
