Fuel trims change at random???
rstchris
448
Oct 5, 2008
kingman, Arizona
I tune my safc perfect and all the sudden it goes way lean, so I tune it again and at random it will go back to rich. I ended up finding the happy medium between the two but that's about 12.9-13.2 cruise/ idle then 15.5-15.9 cruise/ idle. the only thing consistant is WOT. It's always in rich "mode" when cold then switches and at random while warm will go back and forth. I also noticed my car is not making corrective fuel changes "closed loop" and the only code it's throwing is "MAP" I think i have a bad connection inside the ecu on that cause the signal goes to the ecu connector. Will the code i have keep it in open loop and why does my fuel system jump around?
Yeah, but that's not even close to the problem. It's like after driving a while it would seem like my fuel pressure would drop 8-10psi then at random go back up. I know that's not the case but that's how it acts. I have a 170* thermostat, I don't think it would make that much of a diff. though.
So I hooked up a scan tool today and realized the o2b1 volts were "0" :ohdamn: so now that my o2 is working properly I can go into CL. I"ll drive a bit later and make sure it's not gonna switch around on me.
Problem solved, I put in the 660's and tuned in open loop, then plugged the NBo2 and it runs like a dream. :hellyeah:
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
