BoostInsideTSi
- 200
- 1
- May 5, 2004
Aurora,
Illinois
I have had my check engine light on for quite a while, ever since I hooked up my new exhaust with test pipe, so I figured it was just the 2nd o2 sensor giving off a bad signal. I went to the chicago meet yesterday and had someone with a pocketlooger hook me up, and he found 2 problems for the check engine light.
1. fuel trim problem
2. something to do with the idle.
anyway, from what I can remember here, does anyone know what would be causing these problems or what would fix them? Thanks,
Mike
PS. We were having a hard time picking up o2 volts, it was reading like a .01, something like that (only tested at idle). could this be from a bad o2 sensor? I would be able to change my o2 sensor from my test pipe and put it into my o2 housing right?
Mike
