fuel system advice
acdrew
58
Jun 1, 2011
lawton, Oklahoma
I have a 93 gsx eclipse was in bad shape when I got it slowly replacing the bad parts on it. When I first got it the car ran strong has a 16g on it on 25 psi with a gmt 3" maf-t. The 16g went bad so I put a replacement on it with tubular mani and new intercooler and piping. The old piping was all rigged up with like putty or something to cover holes in the piping I plan on running Dsm link v3 so I pulled the safc off. The fuel pump went out and tank was rusting through i dropped the tank and I am gonna put a fuel cell on it I want a fuel setup that's affordable that I can easily upgrade later for a gt40 size turbo but wanna work all the kinks out of the car first anyone got any suggestions .
jmf makes a direct bolt in fuel cell. works with stock pumps and sending unit and even uses the stock filler neck. only problem is its a 7 gallon tank so dont plan any long drives.
summitracing.com has a ton of fuel cells that are universal with capacities from 2 - 25 gallons.
if this is a track car be aware of the requirements for running a fuel cell.
