Fuel System 97' GSX
We'll I hope you have good luck with that kit, :pray: my step bro got a cx racing 20g 5 or 6 years ago, and we'll he got a true 20g next moth after due to it blowing hella oil.
But to your question, depends on what you plan on tunning with and what HP you want. My step bro 20g at 22psi 650 injectors 190 pump, and a SAFC was at 412whp. If your going with DSM link or ECU flash, I would get bigger injectors as you can tuner bigger injectors as 660 inj. 255 pump and a FPR:thumb:
it was on pump AWD I do no he had 20g and 660 injectors SAFC tuned. In the 20's (I just said 22 it sounded good right then) for psi 2.1 or 2.2L, cams of some sort, oversized valves, 6 bolt with 2 g head. Idk what else 5-6 years is a while as this isn't 100% but is as accurate as I could get.
His dyno sheet is still on my step dad's wall at his shop along with his pic of him on dyno and on the drag strip.
Now he has a fox body with ridiculous work done. Ferreira automotive is the shop. I'm in North Carolina or else I would give a pic of him on dyno and a pic of the sheet.
also im trying to get my gsx to 500hp, thats my goal. but i was looking at other turbo kits.
Just a quick search on classifieds and http://www.dsmtuners.com/threads/td05h-20g-7cm.491095/ this one looks good. :idontknow: Their is a bunch on their. But eBay turbos not so good.
Here is a good FMIC
http://www.extremeturbosystems.com/ETS-95-99-Eclipse-2G-DSM-10.5-Race-Intercooler-Kit.html
This is my FMIC
http://www.punishment-racing.com/punishment-racing-fmic-kit-1995-99-eclipse-talon/ should be good for your wants :thumb:
The second kit with the 20g I posted is about the same price for the kit you where looking at.
  • Wanted 6 bolt NT water pipe
    • chrisman287
