Fuel Question
SexyDSM95
775
9
May 1, 2004
West Chester, Pennsylvania
Just a quick question:
I installed a Walbro 255lph pump and I don't have injectors or a larger turbo. If and when I slap on my 3" DP with Evo O2 housing is it safe for me to increase my psi from 15 to 17? Or should I stay safe and maybe just up it to 16? I don't have S-AFC mind you and probably won't get it becaus I am stubborn and want DSMlink instead :p Oh, and what problems may arise from having a 255lph pump and no injectors/turbo just bad gas mileage? LOL
The thing that you need the most right now is an Adjustable Fuel Pressure Regulator.
The bigger pump is overwhelming your stock piece and causing you to run rich at Idle.
Most people will tell you that it is pointless to run more then 15psi on the T-25 but we did dyno my friends T-25 car last night and it made more power at 19psi then it did at 15 :thumb:
Actually I am not running rich at all..... :|
You are more than likely over running your FPR. Your fuel curve won't be linear, but you'll be alright. Yea, go ahead and turn up the boost. I ran 17psi on my T25 on pump gas on a stock pump. I think it's safe to set yours as 17 as well.
Well when I ran at the track and set it to 17 w/o my DP and fuel pump I spiked to around 22. So I was like ummm we will turn that back down to 15. I was thinking maybe boost spike/creep due to not having a full 3" DP and 02 housing. But yea like I stated before I am not running rich what so ever maybe my gas mileage sucks a tad but that's about it. As for wideband I have no logging tool or SAFC so I have no idea.
haha pretty much I most likely am. Well looks like it's time for a FPR! :dsm:
Sandra, get an adjustable pressure regulator soon.
I let it go but you know what?
I had so much fuel for so long that I have a ton of carbon build up in my combustion chambers. And not just on my piston tops either, but on the valves, the roof etc. It will be either take off the head and get it done, or run water injection (and an adj fpr) for a while and steam clean my head.
See, the extra carbon causes knock by raising compression and also by making nice little glowing embers that act like spark plugs, but at the wrong time.
and knock sucks ass.
PS, water injection does not suck ass ;)
Oh jeebus...how long did you run without APR? I honestly can't afford it for maybe another 2 weeks... :cry:
Oh and BTW how much boost were you running?
oh, 2 weeks will do you no harm I don't think. How long have you been running the big pump with the stock regulator already?
As for boost, well, it doesn't matter really, but between 15 and 18 psi.
I slapped it on last Sunday so almost a week. I talked to a couple of my DSM buddies and they said the carbon build up is after LONG term use not a couple months. I was also told that maybe SAFC would be a better bet and AFPR would be pointless for me to have at this point since I don't want to go above 20psi. If I get SAFC I would most likely get 550 or 660 injectors anyway so I would be in the clear. Thanks though guys for the help!
  • For sale 1g 1G Eprom ECU
    1G Eprom ECU $185 + shipping & paypal fees* great for someone with a 1G or GVR4 who wants to...
  • For sale 1g 1G Ortiz Center Vent Dual Gauge Pod ( discontinued )
    1G Ortiz Center Vent Gauge Pod $100 + shipping & paypal fees* long discontinued * gauges are...
  • For sale 1g 1GA Clear Corner Light Set
    1GA Clear Corner Light Set $65 + shipping & paypal fees* all mounting tabs are intactYou...
  • For sale 1g 1GA Talon Grill ( Great Condition )
    1GA Talon Grill $55 + shipping & paypal fees* Great Condition !You must be registered to see...
  • For sale 2g 2G OEM Door Handle Set ( includes seals )
    2G OEM Door Handle Set $55 + shipping & paypal fees* includes both seals* found a flaw on...
