Fuel pump question IMPORTANT !
dsmrunaway1
131
Sep 6, 2003
:dsm: ....is there any possible way that u can tell if there's a fuel pump in ur car with out actually ripping apart ur fuel setup...the guy i bought my car off of awhile ago told me there was a tt supra pump in there....i didn't care when i first bought it...but like every other person out there...the DSM world sucked me in and now i need to know due to the fact i will now be making a descent amount of horse...any inputs would be helpful...would a datalogger help in anyway ??.... :dsm:
The only way to find out is to actually look. A datalogger might help, but more of a tuning resourse. I just say take out your pump to actually figure it out, its not very hard and doesnt take very long to do either. :dsm:
Well... if you have a Supra Fuel pump you should also have an aftermarket FPR (Fuel Pressure Regulator) or else your car would run pretty crappy (datalogger=pig rich). So if the car runs fine... check the FPR. If the FPR is stock... there's a good chance the Fuel pump is stock too.
-Turblown
Yes there is! The easiest way IMO is to put the key in the ignition and crank the engine over. If it starts then there is a fuel pump in the car, if not further diagnosis will be needed. :p
Actually pulling the pump out and looking isn't that hard to do so I'd just do that to see what pump is in there. :thumb:
A supra pump won't be nearly as loud as a Walbro though. They don't call them Whinebro's for nothin!
