Fuel pump not working after a tranny swap
dsmer1G
64
Oct 31, 2007
piedmont, Oklahoma
So I did a auto to manual tranny swap in my dads 96 Spyder non turbo.
I got the wire jumped so the starter works. I primed it with gas and it wants to start, but just dies. I even pulled the return line off when cranking and nothing came out.
I don't hear the pump come on either.
So I'm not getting fuel for some reason.
Edit:
I quess I have it figured out.
Im getting power to the pump but its not working.
So the pump went bad while I was working on the car.:(
I had a ecu, 4 relays, a battery, and my wideband sh!t on my when I replaced my motor. Talk about bullcrap, Try figuring out a electrical problem where everythings bad, and it says "screw you". At least you figured it out!
Man that sucks.
At least I have a couple spares that hopefully works.
  • Wanted 6 bolt NT water pipe
    • chrisman287
