fuel pump not running?
Timothyj94
166
Jun 6, 2011
Glen ellyn, Illinois
I did a swap, I have a 95 non turbo, dropped what I believe is a 98 in there. It wont start now, i believe the fuel pump is not coming on. Any ideas?
Also on the back of the intake there is a little W looking attacment piece (for three hoses) I've got the left and right ones attached, but cant find what goes in the center :ohdamn: Anyone know?
Fuses/relay/wiring? You are way too vague for anyone to offer you any help.
Everything should be fine, my previous engine just blew up so i just swapped, relay clicks i belive. i didnt mess with any wiring
On the '95, they go to the FPR, EGR, and cruise control (if equipped).
Well... verify. Make sure the relay is activating. Make sure the fuel pump fuse isn't blown. If those things check out, check for voltage at the fuel pump.
I am able to jump the relay so it comes on, tested the relay seems fine. So I'm lost. Where is the fuse? Is there some kinda fuel safety cut off?
