AWD-Tony
- 6,787
- 3,750
- Sep 11, 2017
Cincinnati,
Ohio
If you do remove a spark plug, it doesn't have to be super tight when you reinstall it. Just snug + a 1/4 turn. DO NOT HULK it.
I do Marty, but it might be fake news.You have to go under to disconnect the line. If I remember correctly, there’s just one line, 10mm. Make sure to use a line wrench and rust penetrant helps.
Lol. It’s not that bad man. A set of line wrenchs doesn’t cost that much. If you plan on working on your car, it’s great to have.
That line can be a PITA. I had to use vice grips on mine, under the car like tk106 says. Up above, you pull the line (rubber) into the service hole then remove the 8 little nuts and pull the pump assembly up and out. After that I could use line wrenches but not from the first time. They wanted to round that flare nut. The rust penetrant should be put on a few days in advance, if possible.
He has a 2g
Yep, you will likely twist the fitting at the top and that's not good. Same for me here so I went under and disconnected so I could upgrade.
