fuel pump installation for NT
mastaBO
96
Oct 22, 2003
can someone tell me where it is and how i could change it? I found the article for the turbo's but not for N/T's
Thank You~
The pump is located under the rear seat beneath the metal plate on passenger side. Pressure regulator is beneath middle plate. Under the plate, unbolt the six 8mm bolts holding down assembly (Of course, make sure you have disconnected electrical harness, relieved fuel pressure in system, & disconnected battery first. Need more info on how to do any of that, let me know.). With assembly out, it's pretty easy to see how to switch out pumps. Put it back together and replace everything. Altogether a simple job. Good luck.
:rocks:
