Fuel pump a complete mess
horizontalkev
Supporting VIP
1,000
Jun 28, 2010
great bend, Kansas
I am redoing my fuel pump before it causes a fire (previous owners work).. The sending unit has JB Weld all over the place, I will let the pictures talk... My questions will follow after.
3
4
5
6
7
I scraped all the JB Weld off the sending unit and I am planning on buying a steel bulkhead fitting (previous one is aluminum) that I can properly weld on to the sending unit I just have no idea where to begin.. What am I going to need exactly? And how do I seal off the hole in which the two wires from the pump run through? Thanks
My hanger is goofed up in a similar fashion though mine was just a pipe jb welded in a square cut hole. Probably going to do same as you and have a fitting welded on.
Wow, that's not just a fire waiting to happen. That's an explosion. God forbid those two female connectors made contact in a near empty tank of fuel. Weld the unused holes shut or have someone do it for you. As for connecting the pump:
AN Stainless Steel Adapters | ANplumbing.com
I would use the a -6 AN to NPT fitting. Figure out the I.D. of those fittings, put an O-ring on the outlet of the pump and see if it'll be a good fit. Once you find the correct one, weld it to the cover.
Browse that catalog. You might find something that'll work better but that idea is close to how stock pumps are hooked up.
