Fuel Problem on Cold Start
Mike Marnik
349
6
Mar 5, 2004
Omaha, Nebraska
OK so i just removed the engine to replace the balanceshafts and bottom end gaskets and seals. I also removed the emissions at the same time. Now i am having problems with the engine getting fuel on a cold start up. I have to spray starter fluid into at least 2 cylinders if not all for for it to start and have to hold the gas at 3k rpm for a little bit before it will run fine. After i do this it runs great and gets all the fuel it needs. I can even let it sit for a few hours and it will fire right up but if it sits overnight it just cranks. Why would it do this I'm thinking its something with the fuel pressure or something. I did the emissions removal according to the digrams i found in a post on here. any and all help is much appreciated thanks.
ok this afternoon i went to start it and it would it just cranks but i just kept trying at trying and if i turn the key for a sec or 2 u can hear maybe one cylinder fire but after that just cranking. well if i do this 1-2sec turn of the key eventually after a couple trys (5+) it will beging to fire some run for a few secconds then die after a few times of that it will run fine. I know i am always getting spark i checked that but i believe it has to do with fuel. whe i take the spark plug out after cranking it over i dont smell any gas. i need this fixed soon because i have to take this back to college with me, and i dont want to get stuck there with it not starting up.
check your coolant temp senor in the thermostat housing! also make sure the wires going to the sensor or not damaged or cut off! :dsm: :
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
