Resolved Fuel pressure solenoid FPS resistance values?
AtomikRage45
47
Aug 6, 2006
Clementon, New Jersey
Im throwing a code of (P1105) Fuel pressure solenoid.
Does anyone happen to know what the resistance value is so i can jump a resistor across it...
EGR is eliminated
EGR is eliminated
Just use a multimeter and test for the resistance in ohms across the leads of the fuel pressure solenoid. You will also need to apply vaccuum to the solenoid to see how much the resistance changes according to vac pressure. Then you'll have an idea of which ohm resistor you'll need.
what amount of vac pressure should i put threw the solenoid
Actually if you are going to be eliminating the fuel pressure sensor you won't have to pressurize it to get a reading. You would be able to just test the resistance of the solenoid and line it up with a resistor of the same resistance. Make sure though that you buy a resistor that will dissipate the amount of wattage that you will need. The correct ohm load and too small wattage rating is a good way to catch something ablazing. You should be able to get by with a 10 watt rating.
