DJ23GSX
- 773
- 6
- Feb 22, 2004
W. Springfield,
Massachusetts
My first issue is when i shut the car down i lose all fp almost immediately. I mean within 5 seconds the fp gauge is at 0. Today i powered up the fuel pump and pinched off the return line and i was able to hold 70psi solid for a couple of minutes which tells me there aren't any leaks till after my afpr. I've searched under the car and can't find any obvious fuel leaks in the return line. What else should i look at? According to my fuel trims i am running lean no matter how much fuel i add with the safc. My gas milage is horrible. I've been averaging 13-14 miles per gallon lately and thats hardly getting on it too. Would a leak in the return line cause my fp to fall while under boost?
However, I don't want every user who read this to go and immediately take apart the fpr becuase of all the ones I have helped resolved, the problem is at the pump in most cases.
