Fuel Mgmt needed?
Locutus78
158
Jul 21, 2006
Spring, Texas
Good afternoon all! This is my first post here. I found this web site when another forum was not answering my questions, and I did an internet search for a DSM stroker.
Here is my situation. My crank is starting to walk (life's a %^&^%). I have done some research and I am looking at putting in a 2.3 or 2.4 stroker. I know I will be needing to get an AFC. My main question is which would be best for me a SAFC-II or GReddy Emanage? My goals are to have a "different" than everbody around fast daily driver.
Another question, does anyone know where to get a 60mm wideband? I have a slot left in my triple pod (boost, EGT,???), and since I have all GReddy 60mm gauges it is a 60mm pod. I am sure I will have alot more questions as I go along but this will get me going.
Thanks
E-manage with all of the options cost similar to Dsmlink, but it still doesn't have even 20% of the feature's. I would say Dsmlink is the best option for most people.
If the ecu is socketed, the install is very straightforward. If it's not you need to get that done so you can install Dsmlink.
A wideband isn't needed but it makes things a lot easier.
