fuel system gurus needed
coryf1233
246
Nov 6, 2007
hanover, Pennsylvania
So my wideband reads really rich, like below 10 at wot,
at idle it reads 18 really lean, I figure i have a boost leak..
however my fuel trims read lean all the time
whats this all about?
Well first off stock AFR for wot on a dsm is around 9.5:1 so that is fine.
Now dont figure you have a boost leak because if you dont know than you most likely do. Do a test and fix all leaks. Make sure you o2 is ok because when you get stuck into open loop it will run lean at idle and rich during cruise.
well my o2 voltage seems to fluctuate alot, i thought it was suppose to cycle , but it drastically changes, and the other day one of my fuel trims was 199???? whats the deal with that, obviously its wrong but why
