1G Fuel Line Upgrade
Reese92tsi
181
Nov 3, 2004
Raleigh, North Carolina
I would like to know if it would be okay to use the blue line instead of the typical stainless steel line for a complete fuel line upgrade? The blue line is much cheaper and the fittings are also cheaper. From what I read it would be okay to use it but I wanna hear your opinions. Also, what size are the threads are the pump fittings?
Go with stainless if you are going to do it. Rubber lines wont pass safety after a certain e.t. Cant remember what it is though.
Just spend the money and do it right. Slowboy sells a pump to filter kit for $100 IIRC, thats not much money for the peace of mind it gives
The fitting at the pump is 14mm x 1.5 right? The one at the bottom of the stock fuel filter is also 14mm x 1.5 right?
