Fuel issue need input stumped
talon187
1,043
Feb 11, 2003
torrington, Connecticut
Ok guys heres my issue. somtimes when im going up a hill it seems the car will loose power. almost shut off but not. wideband will go blank and it will putt. if i pull over and start the car again it will run normal. one time it ran normal and 30 secs later did it again. I had a ford escort that did the same thing and it was the pump like it lost pressure. The reason why im questioning the pump is because im running 2 bosch 044 pumps. Ive checked wiring its not that. ive got a 4gauge wire going to a block then from the block 8 gauge wire to the pumps with 8 gauge ground. when the car acts up the pumps are still working they do not shut off.
