Fuel Injector Problem
TSI_AWD_95
Oct 20, 2006
Rapid City, South Dakota
Here's the deal, I got 720cc injectors and wanna use a dsm link to run them, well my concern is the injectors I got aren't drop in, if I just put them in as they are the wiggle around, so if i get fuel O rings and put them in there, would that be enough to seal it, or will the fuel pressure be to much? any suggestions would help.
The injectors have to seal at both the fuel rail and in the head.
If they are denso style then they can use the standard insulator and o-ring parts.
If they are Rocjester style (PTE/FIC) you'll need to figure out the best way to make your seal.
Perhaps you can be a little clearer about what the problem is or post a picture.
Steve
The injectors are from RC eng. and the putting them in the fuel rail is where the seal problem is, not the head.
o ring it up baby i have two on mine i have pte 880 and the little green ones they give you really arent up to standerds so i put alittle biut bigger so it squeeze s up in there make sure to put them on the injectors frist you can pick up an o ring kit for little to notthing from autozone or if you have some time e bay has the deals
