fuel for cams
punx04
Nov 11, 2004
san diego, California
well first off i was planning on just sticking with my 14b and using that bullseye o2 housing, good idea for a budget? and then i want to get the comp 101200 cams, worth it for the size of the turbo? and what kind of injectors would i NEED for this kind of set up? if i was only gonna be hitting maybe 16 would i be fine with stock?
I would go with the comp 100s for your aplication. As far as fuel system I would put a 255 on it and stock injectors will be fine at 16psi but no more to be safe.. Always run 93 octane fuel. Change your fuel filter also if you have not done so.
