New Cams Fuel Pressure
bNasty
669
5
Jan 15, 2009
Chantilly, Virginia
What should my new fuel pressure be after installing the cams. Ive left it stock (fpr) 43.5 psi but its strikes me that it should be different now that im getting only 10 inch of mercury of vaccum, should i leave the vaccum line in and just adjust it to 33 psi?
I don't understand why you'd think different cams would require a change in fuel pressure. The reason there is a vacuum line going to the FPR is because a change in manifold pressure needs to be compensated for in fuel pressure at the injectors, otherwise you'd be richer in vacuum and leaner in boost. Changing the fuel pressure changes fuelling. If you use closed loop like stock, changing it will mess up your fuel trims; if you use full-time open loop, changing it will change your AFRs.
I understand, I was just curious becuase now that i have less vaccum it seems like my fuel pressure would be less when i plugged the vaccum line back in?
You would have MORE fuel pressure at less vacuum. 10inHg vacuum is -5psi so your fuel pressure should be LOWERED 5psi -- 43.5-5=38.5. 18inHg is -9psi, which would be 34.5psi. When your boost gauge reads 0 cruising, you're at your base fuel pressure. Anything in vacuum lowers it, boost raises it; it's all in a 1:1 ratio. This is all done because the injectors have to overcome the pressure in the intake to give you the right amount of fuel "everywhere on the boost gauge".
