SpyderGuyGST
- 0
- Nov 15, 2003
I have a bunch of questions relating to this subject so here i go
first, my check engine light came on about 200 miles ago. Im pretty sure its my rear o2 sensor however i have a question on what I should do... I have a straight pipe so im guessing the new o2 sensor is going to keep getting fowld by the exhaust. What should I do about that??
Second, the car keeps fuel cutting in any gear higher then 2nd when under heavy acceleration. I replaced the spark plugs as well as the fuel filter and still the problem persists. Im thinking its because of the o2 sensor, i heard when one is out, the car runs very rich (which im pretty sure is the case because when i step on the gas a nice big puff of black smoke comes out the exhaust).
third, I have a HKS EVC installed and when i turn down the boost (currently running at .90 millabars), under full boost, the psi still reaches 16 however the car deffinatly lacks the power, and when i turn it up to 1.10 millabars, the car has alot more pickup, yet the psi still reads 16 under full pressure...
well i think thats about it
thanks for your help in advance
